Charger port sparking
Discussion in 'Carbon GT' started by jpark13b, May 5, 2017.
More threads by jpark13b
  1. jpark13b
    jpark13b Member
    Was wondering if anyone had this issue before?
  2. Spartan117
    Spartan117 Member
    This why you should first plug in the charging port then the charger itself. If it still sparks (without moving the connector) after fully connected you better turn it of :D
  3. wiztecy
    wiztecy Member
    I never had mine spark, both the 4 amp quick and 2 amp slow chargers when connecting live to my Carbon GT when I owned it. My 2 Metroboards both with 2 & 4 amps don't spark either. I'd contact Evolve and mention this. Issue most likely is that the capacitors in the charger are filling up faster than it should and immediately supplying the high current or possibly they're putting in an underrated capacitor into the charger when they built it.
    jpark13b
    jpark13b Member
    Yea I was thinking the power supply was the issue since it never happened to me til now. It sparked when fully inserted as well. :scream:
  5. Alex
    My Gen 2 does this, apparently it's pretty common.
    I usually plug in the charger first now, just in case. But it still does it sometimes.
    • Informative Informative x 1
  6. OP
    jpark13b
    jpark13b Member
    I talked to evolve support and they said they never had my issue before. I just bought another charger and they sent me a female charger port for free out of warranty. Going to plug in port first from now on since the sparks melted the insulation off the charger barrel plug and won't fit anymore.
  7. wiztecy
    wiztecy Member
    ^ I think you need to change your screen-name now to "spark13b" :)
    • Funny Funny x 2
  8. OP
    jpark13b
    jpark13b Member
    Lol I should! But now the board sparks no more. It was definitely the charger. The new one is doing its job, but just in case I'm taking precautions and plugging the board first before powering the charger.
