Battery only charging to 41v
Discussion in 'Evolve Skateboards' started by Skywalk3r, Mar 23, 2017.
More threads by Skywalk3r
  1. Skywalk3r
    Skywalk3r Member
    The first month I had my CGT it would fully charge to 42v but in the past week it stops charging at 41v. But if I unplug it and plug it back in it will keep charging again to the full 42v.
    What's going on? Is there a problem with the BMS?
    • Interesting Interesting x 1
    Skywalk3r
    Skywalk3r Member
    Also only getting 24mph on a full charge with the 97mm wheels on.... hmmm
    EDIT: Got it up to 24.8mph on my last ride. Still 1mph slower than usual, on a full charge I usually get 25.8ish on flat ground.
  3. jpark13b
    jpark13b Member
    Evolve designed the BMS to charge to 41.5V max. The speed has too many variables: weight, weather, road condition, voltage, etc. Also the motor controller will modulate speed as a function of SoC (probably voltage, not sure). Lower SoC, lower the speed.
    Skywalk3r
    Skywalk3r Member
    Well yeah, when I say 42. I mean 41.6 or whatever it said every night after a full charge. Now it stops at 40.6 and I have to unplug it and plug it back in to get to 41.5/41.6
    Skywalk3r
    Skywalk3r Member
    One of the series in the pack is way off balance I think. So it gets to 4200 fast and stops the charge...? idk if that's causing it and it will fix itself eventually or whats going on
  6. jpark13b
    jpark13b Member
    How off balance are we talking about?
    Skywalk3r
    Skywalk3r Member
    It's about 100 off
  8. jpark13b
    jpark13b Member
    Yea I don't like that. You can put it on the charger and try letting the pack balance and see what happens. If it goes out of balance again, then I'd call Evolve and get a new pack. You said your board is less than 2 months old right?
    • Agree Agree x 1
  9. OP
    Skywalk3r
    Skywalk3r Member
    Yeah it's less than two months old, i'll contact evolve if it stays out of balance. Thanks!
  10. Magpie
    Magpie Member
    Is there a way to bring up the cell balance display like what you've shown with the older remote firmware? I still have a remote that doesn't kick me down to ECO mode under certain battery percent.
  11. jpark13b
    jpark13b Member
    The feature is present in the older remotes. I have one as well. Didn't upgrade because the ECO kick down is unnecessary. The procedure is the same.
    In More Info, Tap right button twice, then tap and hold left button.
