What is the glue holding motor sensor stable?
Discussion in 'Bamboo GTX' started by Zygi, Sep 15, 2019.
  1. Zygi
    Zygi Member
    Hi, I am about to attempt to change all 3 motor bearings (1 as big as wheel bearing and there are two smaller ones). This requires to remove the sensor and reapply the glue holding it.
    Would you know what is this substance called, marked on pic?
  2. Kautschi23
    Kautschi23 Member
    2 Komponenten kleber oder auch epoxid Hartz
Similar Threads - glue holding motor
  1. BigSteve
    6
    5,367
