I thought I would share my tried and tested best skate lube to keep in your toolkits I use a light smeer on my bushings to keep quiet, Use on the AT hubs to stop bearings clicking and help insert. Also great for the motor bearings as you don't want to be pulling them out for a clean like your wheel bearings. Anything that needs lubing this is the best. It's Australian made like Evolve very high melting point, safe with rubber and good in bearings. Sorry to go on and on but thought I would share incase someone was looking for the best lube. {}
I just bought mine from the local Autopro it shouldn't be much more than $6 for 30g I see BCF has it. Inox products should be avalible at most auto stores
