Evolve Baboo Gt Bms problem
Discussion in 'General Eskate Chat' started by digi808, Mar 7, 2025.
More threads by digi808
  1. digi808
    digi808 Member
    Hi, I have a problem with my Evolve Bamboo GT—it won’t turn on. I measured the voltage directly on the battery, and it shows 41.3V, but when I measure the voltage at the BMS output (P-), it only shows 18.6V.
    Could this mean the BMS is faulty?
    The battery is fine I made it last year, and everything has been working until now.
    I have disconnected the cables to the motor controller.
    I need to find out whether the output voltage from the BMS should be the same as the input voltage. (When measuring with B-, I get 41.3V, but when measuring with P-, I get 18.6V.)
    I’m not sure if the issue is with the BMS or the motor controller.
    I would need to find out if the battery with the BMS connected, but disconnected from the motor controller, shows the same values on the output of the BMS as on the input
    Thank you very much for your help!
  2. algongsxr
    algongsxr Member
    Buenos días ,conseguiste arreglarlo. yo en el mío conseguí arreglarlo.
  3. algongsxr
    algongsxr Member
    Me dedico por hobby a hacer baterías y reparar placas base.Me pasaron uno que hacía lo mismo y la reparación consistio en cambiarle un Mosfet de la BMS.
