Bamboo Gt Battery Idea's & Questions
Discussion in 'Bamboo GT' started by Rohlilahla, Dec 19, 2020.
More threads by Rohlilahla
  1. Rohlilahla
    Rohlilahla Member
    Hi,
    I wanna build a new battery for my Bamboo GT. The orginial one is good at the moment, but a little bit too weak.
    But I have a few questions and a few ideas for this:
    1. Which 18680 Cells should I choose?
    The 3500mah cells has a max Current about 10 Amps. The 2600mah brings about 35 Amps.
    What is more important, the max current or the Capatizity?
    (It would be a difference by 14000mah to 10000mah)
    2. In most builds they put the BMS ontop to the controller and they cut out the wood from the deck for enough place.
    If I see it the right way, it should be possible to move the controller on the cooling element about 5mm in Direction to the battery. So I could place the BMS in front of the controller!
    So I shouldn't cut my board....
    Creetings from Germany (Grüße aus Deutschland)
